scotty2066
Hi all,
Need some advice as I'm planning on a full build.
Currently the frame has been stripped and taken to paint. Its going to get a custom midnight blue pearlescent paint with a red hue to it. Should have it back in 3-4 weeks.
I am planning on getting a new set of Rockshox Boxxer Ultimates with red lowers. Currently have my Lyrik set at 180mm so thinking of going to 190mm travel but open to suggestions.
I have a Rockshox Super Deluxe Ultimate coil in the rear already which is sublime and will be keeping this.
I've settled on Megura's for brakes. Probably going to get MT5's and pair them with 220mm rotors on the front and 203mm on the rear with the new MDR-P rotors.
Going to switch to SRAM X01 rear deraulier and shifter with GX cassette.
I have a set of customs wheels - DT Swiss 350 hubs with DT Swis HX531 rims. Need new hubs as they are currently centerlock and need 6 bolt for the brakes.
I have some questions I need help with.
- Knowing that im going to be putting a boxxer on, what offset would people think would be good? Was also thinking of maybe running 29" upfront
- What's the largest rotor and calliper I can have on the rear? Will I be able to fit the Maguras out back?
- What hubs would people recommend or possibly new wheelset like the Spank Spike vibracore 350's
- What kind of stem/bars specs would you look at to help keep weight over the front so the front doesn't lift too much going up steep hills but still is nice on the Downs.
- What dropper post would you run? Going to replace the stock one.
If anyone has more information or can help with the above I would really appreciate it.
I've attached photos of everything taken apart and stripped.
Thanks!
Thanks!
