Yesterday I got a RS Super Deluxe Ultimate delivered from J-Tech, with the MegNeg preinstalled and tuned for my specs.
On the tuning info, it said it should have 17mm sag... and also what clicks of rebound / LSC etc I should have.
When fitted, I sat on the bike. Probably around 3-4kg lighter than in my riding gear... and it sunk to about 40% on the shock indicator. When measuring with a ruler, this was about 20mm.
I cycled on the street outside my house for a minute, and did a couple of bunny hops - and the sag ring was showing it had almost hit full travel.
Does this sound right? I checked the air pressure, and it’s up at 245psi already - which is more than I have in my stock shock (about 220psi / 25% sag).
I’ve never had a NegMeg before, so I’m wondering if they need the sag to be set much higher? I don’t want to go out and ride if it’s not set up correctly and damage the shock.
I’ll speak to J-Tech on Monday, but just wondering if there are any MegNeg experts on here that can advise?
