Levo SL Gen 1 Max insertion of seat tube
andronin
17
20
South Africa
Anyone ever work out the maximum insertion of a Levo SL Large. Want to install a longer dropper so I can slam the seat properly out of the way.
andronin
17
20
South Africa
Using the info from Specialized I have installed a 170mm drop which allows me to slam the seat all the way and so far not hit the seat on bottoming out
G-Sport
322
254
Yorkshire
Found this thread when trying to find the info before buying my SL, so wanted to add my data.
Got a 22 medium SL, which according to the above table can have a max insertion of 216mm (which would have limited me to 160mm drop).
However, using a shim to 31.6 I found I can get the full 180mm drop on a One-up V2 180. There may only be around 216mm if you use a 34.9mm post (though I suspect there is more) but with a 31.6mm shimmed I could get 240mm of One-up in there. The bottom 15mm of the one up is the actuator on the bottom, which I suspect is tucking in between the guide tubes..
End result is 27mm of post between the top of the seat clamp and the seal-collar of the post and 180mm of drop. With suspension fully compressed I still have about 5-10mm of clearance between the seat and the tyre (with the seat fully forwards).
Hope other people find this useful.
552K
