When I was cleaning the pistons before bleeding the brakes I made this but when I was trying to lubricate one of the sides of one piston I took it out too much while I was pulling the rear lever, then I noticed that it was oil coming from inside the piston... Then I cleaned it and bleeded the brake two times (there were a lot of bubbles) but the lever is too loose and it does not brake. I see that it's oil still in the piston... So not sure if I damaged it... Any idea of how to fix it?
