Magicshine vs Exposure
carlbiker
Sep 15, 2020
1,047
455
leeds england
Two decent brands, exposure has the battery integral which I like, magicshine needs a separate bank….
Exposure MaXx-D MK13 Front Light | Tredz Bikes £350 not cheap but for the 2500 lumens it does, EDIT just found it for £285
Magicshine 8000 - £220 on aliexpress, the best in class according to Best mountain bike lights 2021: 14 top-rated options for night riding
Have a scan through the slideshow on the lights, gives a good idea of how rubbish some lights really are…
Magicshine weights
3500
light 109g / 5200mah battery 274g
6500
Light 150g / 10,000mah battery 367g
8000
light 150 / 10,000mah 367g
exposure maxx-d mk13
Light 360g / 11,600mah
Mteam
1,864
1,801
gone
Just get one of the 25 quid led lights from. Amazon or eBay, they're just as good where it counts and you can literally buy 10 of them for the price of one of those above.
Something like this will do the trick, get one on the bars, one on the helmet.
L666GTB
42
35
Isle of Wight
This thread above contains info about Exposure and Magicshine Ebike lights that wire directly into the motor and are powered by the battery.
carlbiker
Sep 15, 2020
1,047
455
leeds england
I should have added I already own an allty olight 1500, wasn’t enough on its own, tried a cheapo Amazon light too same thing. Not saying I couldn’t get used to it but I see now why people get proper ones
Mteam
1,864
1,801
gone
No they're not enough on their own, that's why I said you need two, one on the bars one on the helmet.
carlbiker
Sep 15, 2020
1,047
455
leeds england
I’ll consider, hard to ignore the extra you get from the night sun lights but not spunking cash can be nice…..also the bigger lights sound as though the head one isn’t needed as much
Id also seen this which doesn’t fall into the save the pennies territory but was interesting Exposure Flex E-MTB Front Light but no idea if it’s compatible with the rise or what max lumen output would be, you’d literally just leave it there most likely, weight next to nothing.
B1rdie
894
1,096
Brazil
The magicshine separate battery setup allows you to place the light at the helmet and the power pack at the back pocket of a jersey so you releaf the helmet from that weight.
RustyIron
1,808
2,778
La Habra, California
Magicshine was the first low cost "import" brand that I used when they first started coming into the U.S. about fifteen years ago. They're a good light. But since those days, the Chinese have been making a LOT of lights at much lower prices I've used plenty, and it's not possible to figure out if one is going to be any better than the next. For starters, many look alike, but they're branded differently. If you find one you like today, it just might disappear next month.
My advice is to shop Amazon or Deal Extreme for something that LOOKS like something you want, has a luminosity that seems reasonable, and is cheap. Find your two favorite, and buy one of each. You NEED two lights.
You need one light on your helmet, so you can move your head around to illuminate wherever you need to see. The problem with only one light that is helmet-mounted, is that it's too close to your eyes, and you can't easily see the shadows of rocks, holes, and other trail features. Everything looks flat. You need another light on the bars to illuminate the trail in a way that will allow you to see shadows and trail features.
The last two lights that I bought were about $30 each, back in 2019. And as someone else mentioned, a remote battery saves weight on your head. A heavy light is very uncomfortable.
552K
