Hi.
For those who may be interested, I have updated my lyrik fork of my TL comp 2020 from 150mm to 160mm with the DebonAir C1 - Mj 2021 kit | 160 mm Lyrik / Yari A1 with low friction green SKF seals. What we achieve with the DebonAir kit is to lose the half centimeter that the fork has at rest. After the first test for trialeras, jumps and trails the feeling of softness and touch has improved considerably, nothing to envy the best forks on the market, SKF seals provide extra softness. One very important thing is that when air is introduced, inflate the fork at 10 psi intervals each interval, make 5 fork extensions so that we equalize the two chambers equally (valid for standard forks). This update can be done on all Lyrik and Yari forks from 2016. Attached references and photos.
