Lower rear linkage bolt cracking the frame?
nmcguire
Tasmania
Hey, just wondering you anyone has had this issue. The lower pivot bolt that connects the rear triangle to the front triangle has a fair bit of movement and has caused my frame to crack. I have had this fixed by a carbon repairer and overhauled all the bearings as they were seized and replaced the through-bolt but there is still movement and i am worried that it will crack the carbon frame again making my bike essential worthless. Has anyone experienced this and fixed the issue?
Garrit Verway
10
9
Bright 3741 Australia
Hi there
Your worse case sinario is make a claim against merida
accident warranty 50% frame cost .
My problem new bike jumping up and down to equalise air in rear shock for set up , bottom pivot screw and nut exploded out of the frame, not much material on bolt/nut
554K
