Hello riders,
new to emtb here, riding with Shimano E7000 motor. unfortunately the E7000 display does not have the chart display like E8000.
I notice on the same climb, same speed, different gear:
high gear, low cadence (like under 60 rpm), motor noise is very low, almost quiet. does it mean using less battery power? I used my leg power more.
switch to lower gear, same speed, higher cadence (above 80 rpm). motor noise is higher (still not bad), am I using more battery ?
trying to understand to find sweet cadence for longer range. I read somewhere cadence should be around 80-100 rpm for better battery range.
thanks riders.
thanks riders.
