Levo Gen 2 Lost Bolt (Turbo Levo Comp 2020) (Internal Routing Plastics)
Grannyjones
385
80
England
I lost the bolt for this piece of plastic which holds all the internal routing in place when it goes through that open bit near the Shock.
Does anyone know how I can get a replacement ?
Grannyjones
385
80
England
Does anyone know type of Bolt this missing Bolt is that holds this piece of plastic in place ?
Grannyjones
385
80
England
I tried using the 2 that fix the battens and they just aren't long enough to go through this piece of plastic and into the frame
Maybe it has the same thread though ?
DtEW
206
190
Bay Area, California
It's a flathead Allen (takes a 3mm key), M4 thread, 14mm long. The head is 7.7mm in diameter. The OEM version is black-anodized aluminum.
You should talk to your Specialized dealer, or just go to your local hardware store (or even better, fastener specialty shop) if you don't care about the specific material and finish.
I Loctite (blue) many of the bolts that go into my Levo if they're just securing a minor plastic piece, and hence has a low torque spec. I learned this the hard way by losing one of the brake line securements bolts on the chainstay, not realizing that the hose is meant to flex (and impose a torque on the securements) with any suspension action.
Grannyjones
385
80
England
Thanks for the info thats exactly what I needed
I'll head to the local fastners and hopefully they will be abe to provide some of these screws
554K
