The Flying Dutchman
After a few months of testing variations of the 27.5 Maxxis Assegai on my Trance, I can say it's the best piece of rubber on the market! BUT... not a 10/10...
I run the Assegai in the front in the lighter EXO casing with the "intermediate to soft" Maxx Terra compound, on the tail end I've paired the bulletproof DH casing with the ultra-soft Maxx Gripp option. I've ridden on a wide range of surfaces; muck, rock, roots, road etc on Grade 5 descents through to mellow walking paths.
First impression:
After a delightful and lever-free installation, the first thing that struck me about the Assegai wasn't the grip but the DRAG! A few 100 meters into my first climb I stopped and checked if they were leaking or lost pressure...nope, still sitting on 20PSI front/rear which served me well on my DHF/DHR setup previously. I normally sit in eco mode (+75% assist) for most of my riding but I went to eco+ (+150%) once my lungs and legs started to protest. Even rolling on flowy tracks I noticed the bike doesn't maintain speed when coasting near as well as the DHF/DHR combo. Aggressive turning and maneuvering were also toxic to momentum so I had really focus on keeping my ride as smooth as possible.
The annoyance caused by the heavy drag vapourised once the bike was facing downhill (the steeper the better) and suddenly everything makes sense. The grip is unreal! The bike sticks like glue to any surface at any speed. Where my previous setup would start to skid, the Assegai held it's line even under hard cornering and off-cambers. The side knobs are soft as butter on the Maxx Gripp and act like little rock climber fingers that hold on to the smallest details on the track, there's no danger of dropping into ruts or sliding unexpectantly off roots and rocks. I noticed I struggled to intentionally skid into tight corners by locking up the rear end, which I shouldn't be doing anyway so not a real concern for me!
Long term experiences:
After a few months on the tires, I've slowly been upping the PSI to get more rolling efficiency and this has been a good move. Currently sitting at 30 Front, 35 rear and that feels about right for my 110kg frame. The soft rubber compensates well to recover any grip lost due to higher pressures. My rear tire is getting close to the end of its life with center knobs 70% worn and the side knobs starting to break away and split, not what I expect from a tire that's only about 3 months / 500km old. I do have another DH casing- Maxx Gripp that I bought a few weeks ago that I'm having some remorse buying preemptively. In hindsight, I would have gone for an EXO+ Maxx Terra in the rear to reduce the rolling resistance and wear.
Summary: The only option for a DH focused rider but not a tire I'd recommend for long trail rides or 'flat' terrain. Opt for the EXO or EXO+ with the Maxx Terra and run at higher pressures. It's leaps better than the DHF as a front tire but in the rear, it's pretty even between the DHR and Assegai for more aggressive riding in mind.
Pros:
First impression:
Pros:
- Easy install
- Ultra grippy on mixed surfaces
- Multiple casing and compound options
- Works front and/or rear
- Confidence-inspiring - predictable
- Holds bead - no burps
- Drags like an anchor on the softer compounds and lower pressures
- Faster wearing
- Battery hungry
- Only available in the 2.5' wide option
- DH casing is very heavy, EXO or EXO+ are more sensible
