Long cable dropper options with MM compatible 1x remotes?
All Mountain Coaching
1,332
980
GB
So i need a longer dropper >150 as the Fox isn't long enough, plus once using the 1x remote it pushes the brakes too far in board.
What are my options? Want to keep it cable as it's already been routed.
- KS Lev Integra 175
-9point8 (170/200)
Also, i need the remote to be matchmaker compatible, i don't know whether the standard remotes with the above posts and others are, or whether it would need a 3rd party remote like Wolftooth etc..
Or get the new brand X 170mm - bargain and you could pair it with a wolf tooth remote
Brand-X Ascend XL 170mm Dropper Seatpost | Chain Reaction Cycles
Wolf Tooth Components ReMote Light Action Lever SRAM
Re-Cycle
59
79
Netherlands
I'm very happy with the Bike Yoke 160mm in my (non e-) bike. It works super smooth, the remote lever is a good one and can be attached to Shimano or Sram brakes (you can choose the version, I've got the one with a clamp since I'm using gripshifters).
The "revive" option takes a few seconds, but it saves you the potential trouble that an IFP design often gives. And you don't have to "revive" it often, even if I transport the bike lying in the car it's usually not necessary to do so.
It's certainly a dropper I would recommend.
Fair few members with the Revive who have noting but good thing to say about it.
Gary
Old Tartan Bollocks
10,496
10,702
the internet
I have a brand new boxed and unused Brand-X 170mm dropper here. (31.6)
The new B-X remote is a huge improvement over the original. (not far off the Bontrager remote a lot of previous model B-X owners swap to)
Message me if interested.
In fact i would highly recommend the wolf tooth remote no matter what post you get.
Just as an update, I have just switched from the Woolftooth to the new PNW Loam Lever, and i think its a better bit of kit - quality of the bolts is better (heads on the WT got burred pretty easy), and IMO the lever shape is nicer, and lots of other nice little features. Cheaper too!
Vitus E-Sommet VR - EMTB Forums
1,332
980
GB
You're kidding lol, I just ordered the wolf tooth last night
Wolf tooth is still top notch, my main reason for changing was to do with the Shimano controller, an issue you don't have on the levo. If it wasn't for that i would have stuck with it.
554K
