Levo stand
Stumpy
Staff member
644
622
Essex, UK
Just bought one of these for washing my baby... Custom fit for the Levo (and others)
See here for more info - https://www.facebook.com/StandUpMTB/
Stumpy
Staff member
644
622
Essex, UK
It's a bit more complicated than it should be Tom but here is the info they sent me - you can email them @ [email protected]
I went for the €105 'package'
That includes €30 shipping to the UK, yours might be different depending on where you are... (they are based in Italy)
Hope that helps!
Thank you for your interest in the StandUp! MTB stand for Specialized e-bikes (Turbo Levo and Turbo Kenevo). Please find attached all the information to set an order.
The colour of this stock is orange, it's made of galvanised steel, corrosion resistant, water resistant (perfect to clean your bike easily with a water pipe once it stands on it), epoxy painted and finished to dry in oven. The stainless steel pin is 8 mm perfect for original crankset of 8.5 mm. We recommend to check the diameter of your crankset and let us know if you have changed the original with one with a smaller hole so that we can send you the stand with the pin that fit it. In this case, please indicate the year (2016-2017 or 2018) the model you have (comp, expert, s-works or hardtail), and material (aluminium or carbon) so that we can prepare the perfect fit. Delivery in 4/5 days after receiving the payment.
The delivery cost to the UK is 30.00 €.
Total cost is 97.00 € VAT incl. (67.00 € for the stand, and 30.00 € for delivery with courier).
Furthermore we recently launched an extra accessory that allows to lift up also the frontal wheel or to work on the bike frame once both wheels are taken off. It can be fixed to the stand and the rear bike brake caliper. The cost for this extra is 8.00 € and that can be added to the parcel. Total cost of the stand + new accessory is 105.00 €.
StandUp! team is also glad to introduce a new essential tool for the protection of your bike: StandUp! Protect is answering the need of saving the bottom area of your bike frame and battery from rocks, stones and trunks found on the rail. Furthermore it prevents getting mud and dust into the socket, making the cleaning of this delicate area easier. StandUp! Protect is made of extruded aluminium alloy 6060 thick 2.5 mm, with anti-corrosion treatment, a polyvinyl chloride coated fiberglass sheath, and velcro fastening elements. You can find some pictures here (StandUp! MTB Protect Pictures and how to use it). If you are interested in adding this tool to the order, you will save on shipping costs as one or more StandUp! Protect, at 36.60 € VAT incl. each to be added to the total cost above, can be included in the parcel.
If you are interested in ordering also the StandUp! ThermoCover to save your battery life in low temperatures at 57.60 €, you will be able to save on shipping costs here too as we can send everything in the stand size parcel. Let us know so we can send you more info.
If you want to confirm your order, we ask you to sent us:
- Name / Surname and full address for the delivery and invoice + name of the door bell if different from your name.
- Phone number with prefix of your country for the courier-
- Specify the model and size of the bike
You can proceed with the payment with a bank transfer to:
Isolsolution S.r.l.
Banca Credito Cooperativo di Fano
IBAN: IT 91 D 08519 09360 000060153935
BIC SWIFT: ICRAITRREF0
At the moment we do not accept other payment methods
. To speed up the process, you can send us via email a copy of the receipt of the payment, and we will promptly inform you about every step of the transit including the tracking number, as soon as the courier has collected the parcel. We consider an order effective once the payment is made. Please be careful on the SWIFT code as we require non EU international transfers to us to be made with the OUR instruction.
All the products are designed and produced in Italy. In case you are not satisfied with the stand, you can return it within 10 days since you receive it and we will refund the value of the products to your bank (delivery costs not included).
Confident that you will enjoy the comfort and efficiency of StandUp!, we look forward your reply.
Best regards,
StandUp! team
552K
