Levo Rear Cassette
Mountie
421
254
Canada
Hi I was wondering how I can tell if the rear cassette on my 18 Carbon Expert is worn out? I’ve always replaced the chains before the .75 wear mark and it has only skipped the chain four times in its 1250km lifespan and two times when the rear cassette was packed full of mud the third and fourth when there were vines caught between the cassette gears. It shifts well but the teeth look all different shapes which may be normal as far as I know. Any suggestions?
Thanks in advance,
Mountie
njn
340
178
You could put a new chain on and see if it slips or if there are gaps between the chain and cassette under tension.
I have the same mileage on a EX1 cassette, minimal wear, second chain, should be good for another few hundred miles.
553K
