Other Levo plug non-issue sorted
Unicycle_DG
58
9
Kentucky
Editing original thread / post to share an embarrassing moment someone else might learn from. Male end of Levo Rosenberger plug is a reverse magnet if you accidentally turn it upside down. Just rotate it 180 degrees and the female magnet battery end will accept. Apologies for the unnecessary thread.
KennyB
824
564
Taunton
Yep, just tried it with the plug rotated 180 and it was as the OP described. Look at the plug and the 2 slots must be aligned with the 2 lugs on the battery connection. I usually charge with the bike hanging from a hook, if I try with both wheels on the ground it's not so easy to get the orientation right.
Unicycle_DG
58
9
Kentucky
Thanks KennyB. Folks on this forum are always so helpful.
543K
