I have been hanging my levos from a normal work stand I'm a little nervous of damaging the dropper post. Has anyone found a better way to hang the bikes while working on them?
Hi I have a levo and use a Park PCS 10 stand. I mount the bike as shown below, it’s pretty stable I can remove either wheel and it still balances. You don't mention which stand you are using. The Park stand clamp is 9cm wide my Levo is an XL I’m not sure where they alter the frames for different sizes so if you were going down this route it would be worth measuring the frame on your bike first. Hope this helps.
I know it’s not an ebike in the photo (still saving my pennies) but have just bought this feedback sports scorpion floor stand from winstanleys cycles for £55 fit into the hole in the hollow side of the crank arms comes with 3 different size tubes for different crank arms. Not sure if compatible with all ebikes but a lot easier than a standard bike stand
I use the park stand, but also just got that stand that theolegit shows above - it’s great for standing the bike up quickly, and lifts the rear wheel if you need to turn (chain cleaning etc) - and portable! Recommended ?
