I think the HT has the Original 1.2e motor, rather than the newer 2.1 motor. So slightly less torque in theory, but it says it's still rated at 90nm ?Hi all:
Just wondering if the levo ht has the updated battery and motor that the current levo has?
I am considering a 2020 levo fs for myself and ht for the son but was hoping to use the ht battery as a spare
If the motor/battery combination is the same as the 2019 HT it is interchangeable and you are correct, it is a 400 Wh battery and the 1.2e motor.I think the HT has the Original 1.2e motor, rather than the newer 2.1 motor. So slightly less torque in theory, but it says it's still rated at 90nm ?
I think it also has the M1-400 battery .. So smaller than the 500 and 700 in the levo's
I'm pretty sure @khorn uses the battery out of his better half's hard tail in his FS Levo - so they presumably are interchangeable.
