Levo Gen 3 Levo Gen 3, drive side motor axle o-ring placement
6950rpm
27
16
Isle of Wight
Hi all,
Am reassembling the drive chain after swapping out chainring and cassette but am a little stumped as the correct placement for the o-ring (marked G) as it is just sitting loose and doesn't seem to be sealing anything. I thought I'd check first before reattaching the crank fully and torquing everything up to the correct spec.
Does anyone have a photo or can describe the correct placement for it I'd be grateful.
Thanks in advance.
ScottWest
125
76
Oregon
It sits on the motor spindle behind the crank arm. grease it.... They can stretch out if not placed correctly. Install the crank arm and make sure it is not bulging out somewhere behind the crank arm.
554K
