Levo Gen 2 Levo Expert on Route! Tyre and Brake Question...
KrisScott1990
77
43
Edinburgh
Hi All,
appreciate this has probably been discussed and I have searched the forms. But with my Levo due on Monday I have three questions.
It’s a 2020 Levo Comp, specs day 2.6 front and 2.3 rear tyre, is this right? As I’ve read EU come with 2.6 front and Rear?
Are the standard tyres good? I’ll be going tubeless but I’d rather change then before going tubeless if there not the best, the trails I ride are wet and rooty. so depending on your feedback I’d change then when it arrives, I usually run high roller II’s but I’m considering MM DHF and DHR2 in 2.6’s? Will these fit okay and are they a good choice?
brakes... i haven’t received the bike yet, so I don’t know if there resin only Discs? Can anyone clarify? I usually run Uber bike RaceMatix Pads are these safe to use and better than standard?I noticed uberbike now make E-Matix pads now anyone tried these? Or will normal ones be okay?
more than 3 questions there after writing, coming off a YT Capra CF Pro but looking forward to the Levo arriving!
thanks for your help with the above.
Best,
554K
