Levo Gen 2 Levo Expert Carbon 2019 specifications
super_claret
208
47
North Yorkshire
Not really up on bike tech/jargon but where would I find a complete spec of my Turbo Levo Expert Carbon. I’ve checked all the literature that came with the bike but it’s all just generic stuff. I purchased in Oct 2020 and it came with the extended 4 year warranty, according to Specialised Concept Store, although there’s nothing printed on the receipt to back this up.
I’m wanting a complete detailed list of all specs, as I’m looking at upgrading the wheels and maybe brakes. I want to use the stock wheels for road use and fit some fast rolling tyres. The new set of wheels will be used for XC and bike park/trails etc. I’m not a downhill rider. Amy recommendations for complete Wheelset would be welcomed. I’ve read about the Hope Fortus 30 but are there any others I should be looking at?
Thanks in advance.
salko
1,275
867
SLO
4 year extended warranty for this models is for motor only ...
salko
1,275
867
SLO
super_claret
208
47
North Yorkshire
Thanks for posting that. I did come across something similar when I searched myself but was unsure if it was the same spec, as mine came with a Fox 36 fork?
I suppose the other specs will be the same, so would it be safe to order wheels based on those specs?
salko
1,275
867
SLO
For the wheels you only need to know following:
  • both wheels are 29" and most likely 30mm width
  • front hub is 15x110mm BOOST and rear hub is 12x148mm BOOST
  • you need XD driver on rear hub so you current cassette will fit
  • I recommend ratchet type of driver as it is more durable as pawls
2019 Expert Levos (which came with Rock Shox fork) came in this two color options, is your bike like this? If no, then you might have 2020 model (bought in 2019) which came with Fox fork ...
super_claret
208
47
North Yorkshire
Thanks. Mine was black, so maybe it was a 2020 model. All I know is that it wasn't the up to date model at time of purchase in Oct 2020. Thanks for the wheel info though, that's exactly what I was after.
super_claret
208
47
North Yorkshire
555K
