Levo Gen 2 Levo automatically turning on when being ridden with power off
escrs
289
262
So ive just had my motor rebuilt by Performance bearings
Refitted the motor and done some updates via Mission control and now for some reason if im riding the bike with the power switched off after 10 or so seconds the bike turns on and the motor kicks in
Have Spesh changed something in the updates which causes this or have they always done this but ive never noticed before?
salko
1,281
873
SLO
Sounds like unusual behavior, but why would you ride the bike with a power switched off in a first place? If you think you are saving the battery this way then it is better to switch the support mode to OFF while keeping the system turned ON and the battery will also last forever ...
Or do you maybe mean if you switch support to OFF it automatically changes to one of the modes with enabled support?
Binhill1
🍊 Tango Man 🍊
Mar 7, 2019
3,517
5,478
Strange one 🤔 never heard of that before . My Levo has never done that in 4 years..
RebornRider
641
662
NorCal USA
My 2019 does that when I rotate the crank to clean the chain. I have the old connector style that can by popped out a little bit - enough to break the connection but the two connector pieces stay in contact. This prevents the connector and cable from getting twanged by the rotating crank. If I don't do this connector separation, sometimes the motor will wake itself and run the cranks.
561K
