SteelCityMtber
Hello
I have a 2022 Levo Alloy Comp with the standard TCU
its had its problems and had a new motor ,loom and switch
However its started the "won't switch on" game it likes to play
It won't switch on until you either take the motor to battery plug out and back in or split the TCU plug and reconnect
when you have done that it will switch on and off as normal but then if you leave it for an hour or so you have to do the ritual again
I went out Sunday and had to come back home because it would switch on by doing the above but then it would switch straight off
I took it home and stripped it all and cleaned all wiring and motor connections etc
it has now started the ritual above again but is staying on
I am reluctant to take it in to the shop if its a simple fix as they take the piss with the time span
any ideas
thanks in advance
any ideas
thanks in advance
