Rebound is usually something you tinker with to find your happy place and then you’ll rarely change it. One rule of thumb I’ve found to be true, “set your rebound as fast as possible but as slow as necessary”.
You want it to respond fast enough to be ready for the next bump but not so fast that it’s bouncing or pushing back at you.
It's probably the most important setting on any suspension to having it feel plush where it soaks up the small stuff and bigger hits and doesn't bounce you back all over the place like a pogo stick. Too many people don't run enough rebound, I always start with my settings on the side of too slow and then slowly back it out as I need to.
Normally the reverse, + or turtle to add more rebound damping, slowing down the return to normal position.So the knob on the for says rebound +/-
So presumably + means more bouncing you back and - means less?
Other way around, + is more rebound dampening therefore slower return and less bouncing back. Clockwise in is slow rebound, anti clockwise out is faster rebound.So the knob on the for says rebound +/-
When I got my first ever bike with a suspension fork, I had no idea what the rebound dial did. I played around with it on the street but it didn't appear to do much so I left it (for months!). Despite several unfortunate offs I never linked them to that causal rebound setting. Until one day descending a very bumpy (not rocky or rooty) trail I decided to have another go. I wound the dial all the way one way and rode it. Awful! It felt like my fork had become a pogo stick! So I wound it all the way in the other direction. Bliss! I could not believe what a difference it made.
Once I knew it did something I did a bit of research and discovered that maximum rebound damping might not be the perfect setting. I have been a fan of sorting out my suspension settings ever since.
Download this guide to setting up your suspension, from Bike Rumour and keep a copy. It starts off easy and progresses such that you will come back to it time after time as you progress.
Bikerumor Suspension Setup Series: Full Series PDF - Free Download! - Bikerumor
