Last week I fitted a new front tyre, and decided to go tubeless at the same time.
I have Specialized Roval Traverse carbon wheels - which came with tubeless valves.
I’d already done the rear 2 weeks prior without any issues, and have had several tubeless setups on my Stumpy’s over the years.
The DHF didn’t want to seat, and I didn’t have a charger pump, so I took the wheel with the tyre / glue in to my LBS. Happy to oblige, they inflated, and I went home.
By the time I was home (about 25mins) the tyre was nearly flat!
Thankfully it was still on the rim, so I was able to reinflate with my standard pump.
The leak was from the valve. I tightened it a bit... but that just changed from a huge leak to a smaller one.
I ordered my own Joe Blow Charger pump, and a set of Muc Off valves.
Yesterday, I swapped the valves over. Once again, no issue with the rear, but the front leaks from the valve. The Muc Off valves come with 3 different rubber fittings, so I tried all 3. Same issue. They say they should only be hand tight... so that’s what I did. I then tried a ‘little’ bit tighter. Same issue.
I then tried the Stan’s valves from my Stumpy. Same issue.
Seems to me that the wheel is the issue around the valve hole - and nothing will seal 100%. The standard Muc Off valve sealed enough for me to ride today, but I lost nearly 2psi over my 2 1/2 hour ride.
Any idea how I can fix this... or is this an issue I should go back to my LBS with? Bike is less than 4 weeks old, and the wheels are advertised as ‘tubeless ready’.
