Latest battery software is 4.23.1 & motor software is 5.0.4. Mine was the same way. 26-28kph. Get blevo and your problems are solved! ???Does anyone know what the latest motor and battery firmware versions are?
I bought the bike and use it in Canada, which should mean top motor speed is 20mph/31kph, correct? My SW Turbo Levo seems to top out at ~26kph.
P.S. I'm also in Canada
Blevo unlocks speed limiter! Wheel circumference stays the same.Thanks! Why, because blevo makes it easy to adjust wheel circumference and therefore top speed?
You are welcome! Happy trails!Thanks! Can’t wait to experiment tomorrow.
@JeffMcD why don’t you use Blevo? I just tried it... AWESOME!!! Can easily exceed 40 km/hr/25mph. It’s a totally different ride. I bought the Levo because I wanted to be able to duck out for a 1-2 hour break from work and zip to my local trail. Having a proper top end makes it possible. And it’s SO much fun on flat roads now.
Congrats! Pretty hard to get the shit eating grin off your face isn't it! ???
Yep, I mostly use my Levo for riding around the city trails for some exercise. Its Awesome to be able to ride 40+ kph in the bike lane!Oh ya! It’s incredible! Makes the bike a ton of fun on flat paved roads too. You can rip up the trails and then fly home. Totally recommended and awesome.
Ah, just saw this.Now all you have to do is change your chainring to a 36 tooth and your golden!
With a 36t chainring, Petaling as fast as I can on a flat surface,with speed limiter set to 75, I can get to about the 48kph range. Any down hill decline and I can get 50+. I also have my air pressure in my tires at max pressure (30psi).Ah, just saw this.
Isn't that only for android? I don't have android. Otherwise I would spring for it.@JeffMcD why don’t you use Blevo? I just tried it... AWESOME!!! Can easily exceed 40 km/hr/25mph. It’s a totally different ride. I bought the Levo because I wanted to be able to duck out for a 1-2 hour break from work and zip to my local trail. Having a proper top end makes it possible. And it’s SO much fun on flat roads now.
I have a Turbo, running Blevo on it.. I can get 55kph downhill, my short little legs can peddle upto around 38kph before I tire out. I heard the new Mission Control update limits the speed again, so go Blevo!
Same here. I don’t use Mission Control.
BTW, when your battery is charged, what does Blevo show? Mine shows 80% full, which I think is normal. The batt only charges to 80% in order to extend its life.
I just checked mine and it shows 100% now. Could be some kind of cell balancing that is happening right after you disconnect the charger? Perhaps this is why Specialized says to wait 8 hours after charging, before using the battery.
They do say to wait 8 hours. When I checked the battery level right after disconnecting the charger, it showed 80% in Blevo and it was down 1 bar in the Garmin. 2 days later without any use or further charging, it shows 100%I am not sure, I just unplug the thing and take off, I don't give a second thought to the battery routine. That seems silly to unplug and wait for best performance, is that what they say to do? Guess I should read the owners manual one day
