SwissMountainLeader
Sorry if this isn’t new to you…
I happened on this useful tool that can merge files from the Garmin and Kiox. I’ve tried it on a few files and it basically seems to work. Ideally, the two devices would do this, ie the Kiox as a power meter and/or being able to reliably use broadcast heartbeat.
You can select which data to use, like GPS data from the Garmin with cadence from the Kiox. Given that both are using GPS time the timeline should be spot on.
I do need to test it more but it ought to work, I was about to write something myself because it’s a fairly simple problem.
Combining Strava GPS (TCX|GPX|FIT) files, exporting GPX files from Garmin Connect, and adding time stamps to GPX files - GOTOES free utilities
A Suite of tools to help you Merge, Combine, Repair, and Edit your GPS Tracks before uploading to STRAVA, GARMIN CONNECT, TRAINING PEAKS, RUNKEEPER, and others
gotoes.org
