Late 2021, Kindernay introduced their new internal gear hub, the Kindernay VII. This is a 7 speed drivetrain. Watch our video for the long and illustrated version of the test, or keep reading.
Details
The Kindernay VII costs € 999. For that you get the gear hub, the shifter and a cog for the hub. You also get a “hub cage”. The rear wheel is built around this cage. You have the option to buy additional hub cages to build more wheels. The hub can easily be moved from one wheel to another. If you install the gears on a full suspension bike, you will need the chain tensioner as well. And you’ll need a chain, or a belt.
The gear with the chain tensioner and all other necessary bits is about 1.900g. This isn’t much for an IGH. The new ebike specific Shimano XT 11-speed drivetrain is about 1.700g with a steel...
Continue reading...
