Mikejoneskenevo19
Hi, can anyone suggest where to purchase a gold seatpost collar for kenevo, struggling to find a 38.6mm collar
Doesn't the Kenevo have a 34.9 seat post therefore use a 34.9 collar?? or am I wrong?
Cheers, i’ll Have a good chat when I pick it up on Saturday, I wanted to run a gold theme on the black. It must be possible, I found this on the internetJust found this … So I may be wrong
• Diameter: The internal diameter of the seat clamp must correspond with the external diameter of the seat tube – too big, and the seat post may move in the frame, with the risk of cracking; too small and the collar can’t fit on the top of the tube (and you might damage your frame in trying to force it on). There are five standard seat tube diameters on the market: 28.6mm, 30.0mm, 31.8mm, 34.9mm, and 36.4mm, so once you know the size of your seat tube (measure with a calipers or check your manufacturer’s specifications) make sure to buy a seatclamp that matches.
Note: The seat clamp diameter needs to match the diameter of your seat tube rather than your seatpost, which is a little smaller. For example, a 27.2mm seatpost (a size commonly found on road bikes) fits inside a 28.6mm diameter seat tube, so it’s a 28.6mm clamp you need.
I have seen them before but there is no mention of that size on the internet. Either way I know you will love the new bike, Just be wary of leisure Lakes servicing, it isn't great, check the bike thoroughly before you leave, try and ride it for a mile or so checking everything. when you are 100% then leave.Cheers, i’ll Have a good chat when I pick it up on Saturday, I wanted to run a gold theme on the black. It must be possible, I found this on the internet View attachment 6374 View attachment 6374
Thanks... will do!! Enjoy your week!!I have seen them before but there is no mention of that size on the internet. Either way I know you will love the new bike, Just be wary of leisure Lakes servicing, it isn't great, check the bike thoroughly before you leave, try and ride it for a mile or so checking everything. when you are 100% then leave.
Thanks for the info...
Thanks for taking the time to look for meView attachment 7261
Trickstuff makes a gold one in 38.0mm, it should fit
Mike - did you find one - I'm looking, now. Looking for gold bits for my (soon to be delivered 2020 Levo) - struggling to find a seat clamp!Thanks for taking the time to look for me
