So, two weeks in with my Specialized Kenevo Expert S4.
I tried a lot of other bikes before buying, the Kenevo just clicked, it fits my body perfectly.
I‘ve done about 100 miles on it already, mostly rough single trail, up and down and up and down.
I am very happy - BUT… the suspension setting.
- going over roots I feel like there is a ‚dead way‘ in the front suspension before this satisfying ‚oooshhh‘ sound sets in. In that ‚dead area‘, I guess the smaller bumbs, the front and the rear seem to rather bounce than the suspension following the terrain.
- On bigger impacts, drop of a Meter into not to steep landing, I bottom out in the rear. The front uses almost all the way, 90%, so that‘s fine.
Also on jumps.
Can‘t seem to find the right settings and have been trying all sorts of stuff.
Currently I run
On the Boxxer:
22% SAG
12 click
3 Comp
on the RS super Delixe Select Plus:
30% SAG
-2 clicks from middle position
Butcher stock tires front/rear: 1,7/1.8 bar, roughly 24psi and 26 psi.
I haven‘t messed with tokens and volume spacers yet, but assume to get one or two more tokens in front to go for lower pressure and plusher small pump suspension whilst increasing progression. Same for the rear.
Also thinking about getting the Charger 2.1 upgrade.
I am 5‘11/181cm with an inseam of 85 cm, weighing 74 kg including gear.
Dear forum - I’d appreciate you sharing your height/weight and setting that made the Kenevo work for you. Maybe also share what terrain you ride.
If somebody has an opinion about token/volume spacer usage or the charger upgrade 2.1, I would love to hear about your experience.
Also on jumps.
Currently I run
On the Boxxer:
22% SAG
12 click
3 Comp
30% SAG
