Funky Bolly
Hi like many owners of Kenevo the head bearings are not good ,so for the umpteenth time what’s the best bearing you recommend ? Cheers folks .
Double check but these ones should be right.Hi like many owners of Kenevo the head bearings are not good ,so for the umpteenth time what’s the best bearing you recommend ? Cheers folks .
Nobody reads the manualTry the manual?
The headset uses a 1 1/8” (41.8mm x 30.5 x 8mm, 45x45°) Campagnolo Standard compatible upper bearing and a 1.5” (52mm x 40 x 7mm, 45x45°) lower bearing. Ensure that replacement bearings are compatible with the Specialized headset specification. No tools are needed for installation or removal of both bearings. Grease bearing surfaces before installation.
