Hi, i've got a stock 2021 6.7 Jam² and i would like to improve the handling off the bike. Especialy tight corners, and "trials" like stuff. I'm thinking off changing the forks to a more beefier one than the Recon, but also give it a little more travel for hard hitting stuff. I would like to change the fork for a 160mm thicker one, but i am also conserned that the bike will handle slower with 160mm in the small, tecnical, hairpin type corners. I would like it to be steering faster right already as it is. The offset off the Recon is 42mm, should i look for a fork that has the same offset, or should i buy one with 51mm offset, if i wan't the bike to handle faster? Also, i do not like the stock rear shock, i is just to "bouncy", and i can't find a good tune for my liking, it almost feels like the bike is always riding low in the back. Even though i am not a heavy rider, about 72kg geared up. What aftermarket shock would give a more stable ride?
