Is this normal brake pad wear pattern?
Alpman
63
51
Annecy France
Learned riders, what’s the deal here? I put in a set of Trickstuff organics on my front wheel 400 km ago mainly to stop the sinter squeal but also to see how they would work. Yesterday on a rowdy downhill here in the Alps - I have one of the best mtb areas pretty much to myself these days ? - the front brakes started yowling. At home looked closely and saw quite a lot of meat left on the pads. Adjusted the brakes laterally and went for a test ride. Bugger - still yowling. Took the pads out and immediately saw the problem - I was grinding metal. Ouch. But more puzzling - on closer inspection noted that the wear pattern is off-centre, making it appear as if the pads had more material remaining than they did. Long story short - what’s going on here? Is this normal wear pattern or did I install the pads incorrectly?
salko
1,274
865
SLO
This looks like completely wrong caliper position to me. What is your rotor diameter, brake caliper, forks, caliper adapter? Or post a photo of your brakes.
20,749
I'm with @salko here. I've heard of floating disks .. but it looks like you have floating calipers ! :)
Or the +20mm spacers/post mounts are on the wrong way round ?? 2020 Levo S-Works ?
That's sram spacer on a shimano instruction page :
Alpman
63
51
Annecy France
Guys - I’m a fckn idiot. Just compared the original rear brakes with the pair I bought and yep, idiot child here bought the wrong type. And to make matters worse never even did a rudimentary cross check before installing them. Depressing; I’ll have to be more attentive in future.
20,749
That's better than your post mounts or calipers being on backwards :)
dobbyhasfriends
🌹Old Bloke 🎸
3,254
4,642
Llandovery, Wales
aye, I didnt think they looked quite the right shape
Jdog
262
334
Surrey, UK
Bravo for the honesty :ROFLMAO: I am not sure anything more needs to be said on this matter.
On the plus side - imagine how good those brakes will be once fitted correctly, be like a new setup.
552K
