Levo Gen 3 Is it worth upgrading the stock hubs on the Roval wheels, with THE RATCHET LN UPGRADE KIT?
Dannyned212
9
25
Netherlands
My 2022 Levo Turbo Expert is equipped with the aluminum Roval Traverse wheels. It contains DT Swiss 370 hubs. If I remember correctly
The Ratchet LN upgrade kit makes it possible to convert DT Swiss pawl hubs to the beloved freehub Ratchet System. With just a few simple steps, it is possible to incorporate the benefits of Ratchet Systems, such as the outstanding reliability and adaptability of the engagement angle, in existing DT Swiss pawl system hubs.
Has anyone already done or want to do this upgrade?
Chuckles
21
19
Us
I broke so many spokes on my rear, even with cushcore I finally just got a better wheelset. I'm not going to lie, it's worth it if you can swing it. Even used aluminum with DT350s can be found at a relatively affordable price. Upgrading the royal wheels for me would be a lost cause. I had over 6 broken spokes in the rear and multiple rim hits
Dannyned212
9
25
Netherlands
I ordered the upgrade kit (service kit)
I had the hub apart this weekend and it turns out that I have the 18T in it. Now ordered the 36T, did not dare to take the 54T, this because Rob broke it after 1300 km.
Also read that there is a hybrid version for E-MTB, the 24T. Just don't understand if it would be stronger and better!
Why these are not already included as standard. Ah. small investment and see what it does :)
I don't need other wheels yet, so far these work fine, no spokes broken or otherwise
I will share my experiences.
Stan23
27
7
San Jose, CA
I installed a set of i9 Enduro S wheels on my new Levo with the 1/1 hubs (90 poe) the biggest upgrade was losing a lb off the front wheel setup. I installed using a new DHF tire, as well as a new rotor. So I was able to compare weight side by side. Interestingly, the rear wheel weight was identical to stock.
Dannyned212
9
25
Netherlands
Ratchet upgrade received today. mounted right away, which was very easy. I put them on the scale, as the 18T are solid and the 36T is hollow. Try it quickly, I'm curious to see if I will notice something next weekend.
akira
163
73
SanDiego
The Levo SL S-works comes fitted stock with a 54t star ratchet (photo from specialized website on Levo SL). Is the additional torque from the full motor on a regular Levo the primary concern for upgrading to 54t?
554K
