Salespunk
So, I have been having some interesting experiences since upgrading to 7.4.1. First off the motor output is variable/adaptive with the update. I'm not talking about the standard pedal harder and get more power, this is my fourth Specialized eBike so I am pretty familiar with the platform. Instead I have noticed that it will change the baseline output. Not sure if this is a method to extend battery life, but during a steady climb on the trail setting it will either be in a "power" mode or "light" mode to begin. If I stop pedaling and allow the motor to stop, then start pedaling again it swaps modes. Have tried this 20+ times in the last few days and the stronger mode feels like the bike is in Turbo. Have even switched to Turbo when it alternates to the stronger map and there is close to zero difference. My settings in Trail are 35/100/0/0.
Second is a little scarier. When the bike is in Trail and the map has switched to the more powerful algorithm the power tail (the amount of time the motor runs after you stop pedaling) has gotten significantly longer. The tail is now close to two seconds in some situations. It has come close to causing some bad stuff when pedaling out of a corner for a jump. Twice now the motor has accelerated for so long that it is driving the rear wheel while I am still in the air. The acceleration is so strong that it has sent me front wheel high, like really high, with the motor still running while I am in the air which tries to throw the front wheel even higher. It is also more difficult to control in rocky/technical situations sometimes as well, but that is easier to deal with by just using the rear brake.
Anyone else noticed these changes? If you are running 7.4.1 try pedaling up a constant hill, stop pedaling for a second and let the motor stop while still moving, then pedal again and see if you notice the difference.
