Intra drive Mid drive motor and 8 sp gearbox (EP8 mount)
20,786
This one seems to be moving along a bit. The EP8/E8000 mounting makes it idea for manufacturers to consider instead or to be used as a replacement.
Obviously, that would be no use if you couldn't get/use a compatible battery, so fortunately their batteries are also being designed around the Shimano mounting system.
The whole thing is supposedly also designed to be servicable......
Orange Phase test bike fitted with the system.
Images from Pinkbike :
Potentially less torque in emtb configuration, but that post was almost a year ago, so things may have changed ..
04fuxake
321
205
Porirua, NZ
In over 30 years of cycling/mountain biking, I’ve broken exactly ONE derailleur and that was on a flat piece of cycle path. I don’t get the hate for derailleurs.
TimC7
Ovine Assaulter
Apr 22, 2023
271
1,059
From 2 Nov 2023
TLDR: Intra Drive Ltd has announced an equity crowdfunding campaign on Crowdcube to start production.
Please let this be successful and get rid of derailleurs for good!
553K
