Internal cable routing
vham777
27
20
Switzerland
Hi Guys,
i am going crazy... tried to change my rear break and strapped old an new cable together to get it through the frame... well, didn't work out and broke! so i am trying to get the new cable through the frame blindly, but no chance at all :( do i need to take off the motor in order to see the cable routing??? did any of you do that already or should i consider to go to a bike shop to get it done?
any help apreciated
Br
Mirco
Stormy 107
56
37
Yarm
There's a rubber hose/sheathing that is around all the cables inside the frame to stop them rattling. That's why it does go through, I had the same problem. Just pop out the front 4 bolts and let the motor swing out and you can get access to all the cables.
rb.
388
262
San Jose, usa
Hi Guys,
any help apreciated
Br
Mirco
I actually swapped my rear brake without dropping the motor. (Only because I didn’t have the chain ring tool). Otherwise just remove, or swing down the motor, should only take an extra few minutes and will make the cable routing way less of a headache.
554K
