Instinct A70
sdsyver
Alberta, Canada
New to EMTB’s but have been a Rocky Mountain fanboy for years. Took advantage of the last sale and ordered this. A medium A70. It should be arriving at shop in a day or two. Any words of advice other than calibrate the torque sensor. That one seems to be biggy.
dhjunkie
Bratislava
- Degrease the chain and relube properly (proper chainlube is key for quiet bike on the RMs due to so many pulleys on the drivetrain)
- check the B-Tension screw on the rd to make sure chain is not loose - also after first few rides otherwise you will get chain drops
- calibration, when you turn it on for the first time you will be required to do it anyway (at least so was it the case for me)
- set your custom Tune profile (+2 boost) for all the quick afterwork spins when riding wiht other ebike buddies otherwise you will be the last one on the uphill and spinning the cranks like mad ;) - but dont forget that batteray draisn much faster on +2 boost tune.
552K
