Levo Gen 2 Idle off time
phlodge
76
26
Does anyone know if there is a way to stop the 2019 Levo from turning off after around 15 minutes of being idle.
Usually during coffee and cake break.
I am connected to a Wahoo Bolt and it’s a mither reconnecting, so recorded ride data is often split if I have to start again.
Thanks for the help.
DreamensioN
80
89
Brisbane, Australia
Weird that your Wahoo Bolt has trouble reconnecting. My Levo shuts down, but the Bolt stays on and maintains the ride. When I power back up the Levo it just all reconnects and continues no problem. I assume you're running the latest Wahoo firmware etc?
phlodge
76
26
Hi. Yes, latest firmware is installed. On the odd occasion it does reconnect, mostly not.
it’s a shame the idle cut off time on the Levo can’t be changed.
GDAS
126
88
Surrey, UK
Hi, sorry for resurrecting an old post but I have exactly the same issue: stop for coffee, motor switches off after a while but Bolt stays on, turn motor back on but doesn't reconnect to Bolt (except on the rare occasion like you say, without any detectable pattern). What's also quite annoying, is that when connected, it seems to get the speed & distance from the bike - which in my case is corrupted by having a Levociraptor fitted - whereas when disconnected it gets if from GPS. I'd like to be able to get mode and battery % from the bike via the sensor, but get speed/distance from the GPS, however this doesn't seem to be possible ☹️
554K
