Jono967
I have a 2017 Turbo Levo Fattie which I absolutely love
I have run the Blevo app for the last 18 months with no issue
Over the last few weeks, the bike runs as per normal during the start of the ride then after a while, the motor just stops and no matter what I do I can't get the motor to start again.
I've turned off and on the battery, pulled the battery out then put it back in, turned the app off and on again all with no luck.
The 1st time it happened I rode home under my own steam pulled the crank off unplugged the main plug sprayed RP7 all around it everything looked clean reconnected everything up and the bike worked fine.
Did another 2 rides no issue then yesterday it did exactly the same thing I rode it home again under my own steam. This time all I did was turn it off leaving it in the garage. This morning turned it on and the motor seems to be working fine again and I haven't done anything to it
Any advice would be greatly appreciated
Thanks in advance Jono
