In many of the early posts about the ep8 motor, the concept of "form factor" was mentioned. I kept reading, hoping the meaning would become clear. Is it a good thing or a bad thing to have a higher form factor? Is it even something measurable like numbers or angles? Or is it a concept like colour or shape? Does it have dimensions like density or temperature? Or is a dimensionless quantity like a ratio or a proportion?
I have Googled it and the most relevant definition appeared to be this:
What does form factor mean?
In electronics or electrical the form factor of an alternating current waveform (signal) is the ratio of the RMS (root mean square) value to the average value (mathematical mean of absolute values of all points on the waveform). ... The former can also be defined as the direct current that will produce equivalent heat.
Huh? I really am no wiser.
Is the above the best definition?
If so, does the ep8 have a better or worse form factor than the e8000 and..
What does it mean, just how relevant is it to a rider?
Or is it just different and it really doesn't matter?
