As there no guide or youtube video out there on how to replace the bearing of the rocker I thought I post how I did it.
A friend of mine went to the lbs and they wouldn't touch it unless they get support of haibike wich they diddnt get so I attempted it myself
Due to the odd shape its very hard to push them in straight
The only way I found was tapping 1 bearing out and modifying the press kit I had with washer and a nut
My kit is actually a wheel bearing press but its works great for other frame bearings, only thing is you have to fiddle around with different adapters
I applied lots and lots of grease to make it go in easy, but still that was a challenge to push them in straight
If you can create some like I have with an adapter that fits in the bearing and pull it tight with a nut and a washer you can put another one on the other side and tighten that nut
