Levo Gen 2 How freely do your cranks spin backwards ?
DuncanDoughnuts
315
171
Cape Town/JHB/Rippon
So I had the bike in the stand I happen to spin the cranks backwards and notice a crunchie sound coming from them every 1/4 of a revolution... I would assume that perhaps there is some water in the bearings ? They also do not spin as freely as another bike I tested.
How can I clean the and re-lube the bearings as its all in the mother casing? Or I just keep riding it and get it replaced once it seizes ?
In the mean time I took a old Enduro seal BB cover and put it on the crankshaft under the Plastic motor cover to stop any more moisture getting in there ....
ANy advice on how I can get my cranks nice and smooth again ?
KennyB
824
564
Taunton
To take the chainring off you just need an Allan key. If you mean take the spider off, I believe you need a puller plus a Brose spline cover (S175300006) too avoid damage to the bearings - apparently quite expensive.
DuncanDoughnuts
315
171
Of course it will be expensive ..... it’s specialised . Let me try clean it up without taking it off...but you can’t get under the plastic motor cover without removing the spider..
KennyB
824
564
Taunton
I just googled the part number and not that expensive. Don't know about your part of the world though.
552K
