ah..sorry I did not see your reply. Problem solved if that is the case. I would add however that I have never agreed with the often given advice to check pivot bolts and tighten if loose. Check they are tight of course but if they are loose they need to be removed, cleaned and Loctite re-applied. Disturbing a loctited bolt means the Loctite bond is broken and thereafter useless.The back one is internal hex with nut on outside (same side) so use allen head in torque wrench and spanner on outside nut.
Front one is allen hex on one side and 2 sided nut on opposite side.
My front one kept loosening itself and needed extra loctite.....been fine ever since, yep let it cure a bit first....just to add..it is also the case that Loctite takes time to form a full bond so the bike should not be used for at least a few hours...preferably 12 hours I think for Blue Loctite.
I did mine today i used a torque wrench and the nuts that hold it on are 19mm across the flats, so a 19mm open end spanner fits.Can anyone advise me on how to tighten these two bolts? I have a torque wrench and when I try to check they are at correct torque the whole bolt rotates all the time.
Two year old thread?Hey there! Tightening bolts can sometimes be a challenge, especially when the bolt rotates all the time.
