Hi,
trying to help a friend whose 12 speed Hope 4 pro microspline freehub collapsed.
The bike started making noises and an occasional slip could be felt at the cranks. A quick inspection of the drivetrain revealed the cassette had some side play. With the cassette ( SLX M7100) removed it was evident the sideplay was in the freehub. Pulling the freehub off resulted in the outer bearing inner race, ball bearings etc all just falling out on the floor, leaving just the outer ring in the freehub body.
So here is my question:
A Hope pro 4 HG freehub usually consists of 2 bearings separated by a spacer tube only whereas most Microspline freehubs ( e.g. DT Swiss) have 2 bearings separated by a spacer tube AND the inner bearing is secured with a circlip. I cannot find any information specifically on Hope Pro 4 freehub bearing replacement. Clearly to rebuild my friends freehub with new bearings it would help to know which of those 2 different set ups it is.
( I could determine for myself if I had the broken freehub in my hand but I am helping remotely so trying to a void confusion!!)
