Has anyone on here fitted some 203mm Hope floating rotors on their bike, I’m looking at getting some but not sure if the rivets will rub on the rear brake calliper, mine in the V1 2020 e150rs, any help would be appreciated please.
I fitted them to my e150rs and no rubbing but you will have to bend the magnet mount slightly as the bolt holes are slightly recessed so caused the magnet to rub. The rivets on the rotors were fine, ive had no problems with warping and much better with brake fade than with the centrelinesThanks for the links mate, I wanted the Hope rotors partly for the colour but mainly because of their build quality reputation, I have Uber bike radiators on my bike at the moment and they have the big rivet’s so I don’t see why the Hope rotors shouldn’t fit, at the moment I’ve got to sort out my stuck frame bearing outer race, once it’s done, I’ll look at new rotors
I did away with the OEM magnet and bought an ultra thin flat circular magnet with a hole in it and riveted it to my rotor, it’s still working fineI fitted them to my e150rs and no rubbing but you will have to bend the magnet mount slightly as the bolt holes are slightly recessed so caused the magnet to rub. The rivets on the rotors were fine, ive had no problems with warping and much better with brake fade than with the centrelines
