I tired and failed to get one to work with my Sram Guide RE's, rivets on rotor hit the caliper.
Hmm dam, did you try a stand off wash to add 3mm or 5mm ?
oh ok ..No i didn't, i considered it, but reason for swapping disc was to try and sort out squealing brake, so ended up just putting new sram disc on.
No. it will make bugger all difference in use
it's actually only 1.5 or 2.5mm leverage difference..
I wouldn't ever buy another hope floating rotor either. Mine developed loads of rotational play as the rivets wore. lock the front brake on and you could move the wheel forwards and backwards Hope said that's acceptible. Not as far as I'm concerned it isn't
Did you manage to sort this?Thats good to know .. I don't need new play problems thanks Gary!
