Product Image:
Product name: Hope Ebike 2.3mm heavy duty brake rotors
Price paid: £81 for the pair
Score (out of 10): 10
Review: I hope this helps someone as I have had trouble with my 2020 Levo Comp brakes since I bought it and until now, have hated them but couldn’t justify an upgrade when I had something that works already.
I have 2 Levo's to maintain, mine and my sons.
His had the centrelock rotors and shimano SLX brakes
It took a few months but we got sick of straightening his rotors and swapped them for the hope wheels and brake rotors and have had no issues since.
My levo has guide RE brakes and 200mm SRAM centerline rotors and I stuck with mine for just over 2 years. I just lived with having to straighten them after every ride but they got to the point where they couldn’t be straightened anymore so that bike now also has hope wheels and rotors.
The Hope rotors are substantially thicker, they give a satisfying ring when you flick them with your fingernail, they are definitely far more solid, dissipate the heat more and so far, after having been fitted for 6 months or so, have not warped once.
Currently have them fitted with CL VRX brake pads that I fitted at the same time, I also reset the brake calipers by pushing the pistons fully home (necessary as the new discs are thicker) and did a full brake bleed and fluid replacement with the result that the brakes perform far better now than they did when they were new. I had almost given up hope of ever getting the Guide RE working well but this combo is like a stick in the spokes and with very little pull force or travel at the lever.
The rotors weigh 240 grams each, 33 grams heavier than the centerlines and so for me it’s a no brainer upgrade.
