How does it impact climbing? My mate has a lapierre overvolt am 900i ultimate with a 16t and 50 t on the back, i think im right in saying thst should make climbing considerably easier for him?I out pedal the bike using stock 32t ring. This slows down the pedaling.So what’s the pros/cons of this mod? Seems to be quite popular
What 36 ring you use ? I can’t find the bolt pattern anywhere.
sweeeeet! I just ordered one : )You don't need a longer chain. In fact if you don't do it, you need to shorten your chain.
It impacts climbs. You won't be able to climb the steepest hills unless you have a motor to help, but it climbs fine with assist.
Upside is you can pedal better above 20mph.
You can still use the chainguide as designed if you get my adaptor from matter-replicator.com
Actually I went the other way and am using a Wolf Tooth 30 tooth. I'm rarely on anything flat and am usually climbing steep stuff whenever possible. I did have to shorten the chainDid you have to replace with longer chain ?
does going to a 36 bring the chain below the level of the BB? currently on the stock 32, it sits within the protection of the BB/motor coverYes I did 36 and also 38.
Brilliant mod I just did, to be fair it needed it after dropping from 2.8 to 2.6 tyres, which reduced the wheel circumference. I am trying a renthal alu 36. I’m (slightly optimistically) hoping it will be rugged enough.
chain guide fits as designed with a very fine shim to centre the device on the ring. Drivetrain is noticeably quieter with the alu ring. Gearing is much better to me. Using a greater spread of available ratios. New cassette and chain fitted at same time, ouch!
Not sure but I think I would
My 38 is a few mm lower than the motor cover, but I think I would rather have my chain hit a log than my bike frame.
Question: Is it difficult to get the crank arm off? Do you need a puller or are they self-extracting?
My 2020 was self extracting. It’s wasn’t hard at all.I have wanted to install a bigger ring from the first day riding my 2016 Levo. Praxis will soon release thier steel "eRing" products for ebikes. Steel, same thickness and offset as OEM and only USD$25.
