HELP!!Fox Shox Mounting Kit Size
GEE ARR
41
17
MIDLANDS
Hi Everyone,
I'm struggling to fit a new Fox Factory shock to my 19 Levo. Does anyone know if the mounting kit is either 6mm x 20.00mm or 6mm x 20.8mm? Sorry if this has been discussed elsewhere...i've searched with no joy.
Ask TF Tuned, you will get the correct answer - pretty sure someone on here has fitted that shock, but you will get the right answer out of TF.
GEE ARR
41
17
MIDLANDS
Yes I'm sure I read that on this forum that someone has had the same issue, that's why i put it in my original post hoping that person may see this and reply with the correct size. I have discussed with the LBS and they did call TF but couldn't get a straight answer I believe. Anyway I've emailed them myself...let's see what they come back with.
552K
