Zayd Proctor
Having built my first emtb, I now need to get one for my girlfriend who, like me, is new to both emtb and mtb. I was thinking something used, under 3000€. Entry level components will do just fine.
I think the most important thing here is the choice of motor. Ideally, I'd go with the Bafang M510 because it works with custom batteries, it's serviceable, it can be derestricted, it's easy to upgrade to the M560 if needed.
The problem is that there aren't many offerings with that motor. The best I could find is this refurbished Berria Mako for 3100€.
I have no idea how the other motors compare with Bafang. This is where I need your help. What would you choose?
Here's a comparison of the main mid-drive motors for eMTBs, covering their pros and cons to help you choose the best one for your needs.
Best for: Custom builds, high power, DIY enthusiasts
Pros:
✔ High power & torque (M620: 160Nm, M600: 120Nm)
✔ Open system → works with aftermarket batteries
✔ Customizable via third-party apps & programming
✔ Easy to repair with widely available parts
✔ Affordable compared to premium brands
Cons:
✘ Less refined power delivery, can feel jerky
✘ Noisy at high torque levels
✘ Can overheat under sustained load
✘ Heavier than Bosch/Shimano motors
Best for: Reliability, smooth power delivery, premium eMTBs
Pros:
✔ Excellent power curve & natural feel
✔ High reliability & premium build quality
✔ Strong dealer support & service network
✔ Smooth integration with eMTB components (ABS, Kiox, etc.)
✔ Good battery efficiency
Cons:
✘ Requires proprietary batteries
✘ Firmware locked, no DIY tuning
✘ Expensive motor & parts
✘ Some overheating issues on long climbs
Best for: Lightweight builds, natural pedal feel
Pros:
✔ Lightest mid-drive motor (~2.6kg for EP8)
✔ Smooth, natural pedal assist
✔ Compact design with good ground clearance
✔ Efficient power usage for longer rides
✔ Works well with standard MTB drivetrains
Cons:
✘ Less torque than Bosch/Bafang (EP8: 85Nm)
✘ Can overheat under heavy loads
✘ Sensitive to firmware updates that may reduce performance
✘ Limited aftermarket tuning options
Best for: Quiet operation, premium feel, integrated eMTBs (Specialized, Rotwild, etc.)
Pros:
✔ Smoothest & quietest motor in the market
✔ High torque (90Nm) with natural power delivery
✔ Compact & lightweight (~2.9kg)
✔ Good integration with premium brands (Specialized, Rotwild)
✔ No resistance when pedaling without power
Cons:
✘ Brose motors have had reliability issues (belt failures, water ingress)
✘ Proprietary system → harder to repair or customize
✘ Limited third-party support & expensive replacement parts
✘ Specialized versions locked to their ecosystem
Best for: Power & durability, alternative to Bosch/Shimano
Pros:
✔ Strong torque (PW-X3: 85Nm)
✔ Reliable and robust build (good for long-term use)
✔ Works with both proprietary & third-party batteries in some cases
✔ Responsive motor engagement (good for technical trails)
✔ Less software restriction compared to Bosch/Shimano
Cons:
✘ Heavier than Shimano/Brose (~3.1kg)
✘ Power delivery less refined than Bosch/Shimano
✘ Fewer eMTB brand integrations compared to Bosch/Shimano
✘ Aftermarket tuning options are limited
BAFANG (M500, M600, M620)
⚙ BOSCH (Performance Line CX, Smart System)
SHIMANO (EP8, E8000, E7000)
BROSE (Drive S Mag, Drive T, Specialized Turbo Levo/Kenevo)
YAMAHA (PW-X3, PWseries S2, PW-X2)
Which One to Choose?
Motor | Best For | Torque (Nm) | Weight (kg) | Customization | Battery Flexibility | Reliability |
Bafang M600/M620 | Power & DIY | 120-160 | 3.6-5.3 | ![]() | ![]() | ![]() |
Bosch CX | All-round performance | 85 | 2.9 | ![]() | ![]() | ![]() |
Shimano EP8 | Lightweight, smooth ride | 85 | 2.6 | ![]() | ![]() | ![]() |
Brose S Mag | Quiet, premium feel | 90 | 2.9 | ![]() | ![]() | ![]() |
Yamaha PW-X3 | Durability & power | 85 | 3.1 | ![]() | ![]() | ![]() |
Final Thoughts
- If you want customization & repairability: Bafang
- If you want premium reliability & smooth ride: Bosch or Brose
- If you prefer lightweight & efficiency: Shimano EP8
- If you need durability & power: Yamaha
