Help and advice - Llanelli - Open Brose motor ?
Gareth Bowen
69
19
South Wales
Location Llanelli
Need to take my 3 year old levo for repairs. Do not have proper tools to remove crank etc.
Am under lockdown
Any recommendations
Would appreciate any advice.
Gar B
20,794
If you can drop the motor with the cranks connected and so on, you might be able to send it complete to somewhere like Berkshire cycles or wherever you had in mind and they would obviously have the facilities to remove things and then re-assemble it for you and return it in the same state (but working).
Gareth Bowen
69
19
South Wales
Thanks for quick reply?
Motor is fine but I need
Motor is fine.
Just happened to remove the chain guide to replace it and locater backplate has dropped into motor housing
#lazy
E*POWAH BOSS
Oct 1, 2019
1,407
1,535
Aren’t dealers prohibited to open the motors ?
Edit arh it’s fell in the housing ! Wouldn’t it be easier to buy the tool ?
6,554
5,044
You just need a puller......borrow one or order one online. 1min 44sec on the video shows you the tool.
554K
